hi guys trying to open the boat for the season.
Charged the batteries and to start and it is just cranking. Checked and im getting fuel from the carb so i dont think its a fuel issue, for now... anyway, next I figured it might be an ingnition problem. So i pull a few spark plugs and i get no spark. Since i was able to run the boat a few months ago i find it strange that multiple spark plugs went bad. So i test power to the ignition coil. I have about 10.56 volts going to the postive of the coil, and .55 volts on the negative this is with key on.
Bad coil ? I tried to test the coil another way i connected it to a battery and ran some wires from the coil to a pulled spark plug and i got spark on the plug so that made me think its not a bad coil.
Im really not sure where to go from here. Shoud i test the distrubutor next ? If so how do i do that ?
Btw its a 1990 4.3 merc
of note before i closed it last year i had to replace the choke thermostat sensor on the side of the carb and i didnt get a chance to run it with it on. Could that be bad or the wrong part ? Any advice id apperciate.
Thanks
Thanks
