Re: 4.3 OMC 1988 Larson
Ayuh,... There's a block drain on each side, down low,+ a drain on the bottom of each manifold...
The risers may, or may not have a drain each...
If P/S equiped, the cooler needs draining,+ the Big hose should be pulled from the circulating pump...
