Hi everyone- new to iboats, new to forums. Forgive me if I come off stupid ahead of time...
Here's my issue, hoping someone can help with some advice.
Started with a hole in the oil pan. Pulled engine replaced the pan, everything seemed fine.
Took the boat out and it runs great at slow speeds. Starts up fine, sounds good.
Once you open up the throttle, it picks up speed, planes out fine runs great. Then shortly after, it began to lose power. If you keep the throttle down you can hear this loud click from the engine compartment. The first time out the boat would sputter and pop then sometimes stall out. If I bring it back down to low Rpm it goes back to normal and I can open it up again with the same problem.
Took it home did some digging. Found one of the plugs on the dist cap wasn't seated properly, or at all for that matter. Took the fuel line off of the carb inlet and found what looked to be a small amount of sand in the filter.
Took the boat out again this weekend and the same problem happened, but it did seem to run better and take longer before it lost power. The clicking sounds like something flapping almost. Any quick trouble shooting methods out there to try? Should my first step be get an external tank and see if I have the same problem? Has anyone had this kind of problem? Engine info below.
Mcm 176
B627270
262 cid 4.3 l v6
1985-1987
Appreciate any advice and help.
Mcm 176
B627270
262 cid 4.3 l v6
1985-1987
