4.3L, 2bbl Mercarb stalling on acceleration before and after carb rebuild
b18apwr
I've been searching tons of old threads looking for my situation, but haven't really found anything, so here goes:
Last year, I started having an issue with the boat bogging, stalling, hesitating, etc. on acceleration. I was also having issues with cold starts. I couldn't ever get the boat to cold start without a bit of effort. The stalling behavior only happens after you've been running for a little while and then shut down. No matter how little or much you sit, when you restart - and it restarts perfectly - as you accelerate, the boat will settle all the way back down to idle. If I pull the throttle back to idle, the boat will keep running. If I leave the throttle about where it was (1/3-1/2 throttle usually), the boat will die. If I keep it running, I can then accelerate again and everything is fine. I can move all through the range of throttle as quickly or slowly as I wish and it won't stall. It only does it once, right after a restart from sitting.
This spring, I had the 2bbl Mercarb rebuilt by a local marine shop. I was figuring on a bad accelerator pump. The mechanic told me the rubber seal on my old one had dry rotted. I got the boat in the water after the rebuild. No more hard starting when cold. The first weekend out, the boat did great. That was the last time it was fine. The hesitation is back, just as bad as before. However, my cold start issues are resolved. What am I missing? Is this vapor lock? Anti-siphon? I haven't had the chance to check my timing, but I would expect more consistency if that were the issue.
Any help is greatly appreciated. Thanks in advance!
Re: 4.3L, 2bbl Mercarb stalling on acceleration before and after carb rebuild
Ayuh,.... Have ya checked the fuel filters for crud,..??
b18apwr
The filter "screen" at the carb was replaced during the rebuild. The spin-on, in-line filter was replaced as part of the winterization. Unless it got gunked up again after the first weekend out this season...... I'll take a look at it when I'm back in town this weekend. When I pulled last year's filter off at winterization, I turned it over and dumped the contents into a mason jar. The filter looked great. No signs of muck or debris. Fuel came out nice and clean. I can't imagine having the issue on the old filter and the new filter both after just a single outing. I guess anything is possible. Thanks for the advice.
conk3416
I would make sure to check the timing. And also did u have a full tank when it is hesitating on you. The fuel pickup hose in the tank may have moved on you and isnt sucking fuel properly. You may want to fill it up and take it out to see if it still hesitates
b18apwr
Thanks. I'll check the timing this weekend. As far as fuel goes, when it happened this weekend, the needle wasn't hardly even off of the full mark. I had probably burned less than 2 gallons of a completely full tank.
