4.3L Carb Float height
dcf1999
Good Morning,
Does anyone know the correct float height for 4.3L mercarb?
TSB 97-8 (created June 1999) says 9/16 float level and 1 3/32 drop.
My service manual has same numbers in the spec part in the carb section BUT in the carb assembly section it gives a float level of 11/32 and drop of 15/16. The manual is dated November of 1999, so printed after the TSP? Is one a typo?
So which one is correct for the level and height?
I searched this forum and couldn’t find specific answer. I found an exact same situation, but it was for a TKS, which I don’t have, and didn’t know Id that mattered.
I attached pages as reference.
Thanks.
Fun Times
Seems some of it may depend on what design needle and seat your carb has and probably the year/serial number you have too.
Generally the service bulletin is more accurate when there’s a discrepancy in the manual.
By chance do you know where the setting measurement was when you opened it up for reference points?
Scott06
Good Morning,
Thanks.
depends on if you have a spring loaded needle and seat or not
mikes is a good place for parts and rebuild kits if you need them
