tahoejag
- Jul 4, 2009
- 229
Recently noticed starboard riser VERY HOT, port side cool. Running under normal conditions, normal temp reading (aprx 175-fairly new thermo and impeller). Check balls are free and seems to have water running thru and into both risers. On the mufffs, noticed water from y pipe on port side of transom is warm (the side the riser is cool), while water on starboard side of y pipe is cool (the side the riser is very hot). With engine off now, unhooked hoses from t-stat housing where check balls and ran hose water thru them to the manifolds. Had even water flow thru y pipe on both port and starboard sides. It is a raw water cooling system. Normal temp reading on gauge. Can't figure this out....Maybe clogged riser?? Riser is VERY HOT, could it have damaged anything being this hot and running boat?
2006 4.3l carb TKS
180 degree t-stat
2006 4.3l carb TKS
180 degree t-stat
