Engine: 4.3L V6 0F586331
After replacing the outdrive, I hooked the muffs up and tried to start the engine. The motor has been sitting for a couple of weeks since the last time out so it was slow to start. I got it to finally start but dropped the throttle too quick and it puttered out. By now, the battery had died so I put a charger on it and tried to start the boat again. I got the very telling "CLUNK" of a hydrolock.
I pulled all of the plugs in order to check and see if the motor itself was siezed and found A LOT of fluid in the #6 cylinder. I pulled all of the rest of the plugs, turned the motor to get the moisture out, sprayed some oil in the cylinders, replaced the plugs, and she started right up. I ran for around 10 minutes with muffs and she ran great. Shut it off and started back up with no problems. After doing this a few times, I finally got the "CLUNK" again. I checked the #6 cylinder and didn't find any fluid. I tried to crank it with the plug out of #6 and it wouldn't turn. I pulled the rest of the plugs one by one in order to determine which one would release enough pressure to allow the starter to turn the motor. This time, the problem cylinder was #2. I didn't see any fluid come out, but that was the only one that allowed the motor to turn.
I started the motor up with the #2 plug out and ran for a bit but didn't see any fluid coming out. And when I tried to start, there was still a slight clunk before it finally turned. I finally decided to kill the water and run for a little bit to dry out the cylinders and call it a day. I did check the engine oil after all of this. It was a pretty color with no milky characteristic to it at all.
So what do y'all think I'm looking at? Is a cracked head ruled out since I'm not seeing any water in the oil? Blown head gasket?
Thanks for the consideration guys.
