achris
More fish than mountain goat
- May 19, 2004
- 27,468
Re: 4.3l V6 Swap Out
Sounds like you should pull the engine and re-check things like bearing caps. Did the all pistons move through their full stroke length before you attached them to the crank? Another thing that could cause the crank to not turn is the cam and all its drive gears. Did you make sure the cam timing was right and that it turned ok?<br /><br />Chris.........
