dingbat
- Nov 20, 2001
- 17,091
Does a 4 blade prop act differently at high RPM than a 3 blade? I have a 4 blade Renegade (14 ? x 17) on the 22’ walkaround with a 200 HP Ocean Pro
. I certainly can’t complain about the holeshot. For a boat as heavy as it is it gets out of the hole nicely and cruises well at 26-27 knots @ 4300-4500 rpm but I have a weird phenomenon that only seems to happen at elevated RPM. Once I get up around 30 knots I can dump the throttle and I get what I can best describe as slipping clutch type fell. Its doen't sound like it venting.
It only occurs for brief second and I don’t get a noticeable increase in RPM but its there none the less. Thought about a slipping hub but I would think that a slipping hub would show it’s face during a hole shot.
Using the prop calculator I’m coming up with 18% slip (39 MPH @ 5500 RPM) if it means anything.
