Re: 4 stroke oil change
You make it hard to stay on topic and you also embellish meanings to my postings that are out of context. <br /><br />What's in the base stock is important to me whether you think it's BS or not. No need to lecture me on any of this and nowhere did I mention about my experience being more or less than anyone else. However, you may want to increase yours. Ridicule from someone who doesn't agree with me isn't doing anything for the discussion. Just post something constructive to answer PAKev's questions and forget I exist.Originally posted by Old Curmudgeon:<br /> Do you own a 4 stroke and store it? If so what type of oil do you use and have you pulled the valve covers and checked for corrosion?<br /><br />I have a 2004 DF140, my boat is usually inactive from November to March, and I've used AmsOil 10-40 marine 4 stroke since the 20 hr check. And yes, I saw the valves at the 100 hour this summer, they were clean, and required no adjustment. I also previously owned a DT140 for 15 years, a Johnson 70 for 15, and ran synthetics for most of their lives. Only internal problems came from fuel issues before I started using a stabilizer. I've also run 3 vehicles over 450k on synthetics, from Alaska to Florida, and none were repaired/replaced because of internal engine problems. Yeah, I have some practical test data, so lighten up, you're not the only one around with some experience.<br /><br />I'm not surprized you had a problem with rusting valve trains considering where you "hang" your boat. I've found saltwater environments to be corrosive to just about anything metal, stainless included, and particularly when in close proximity 24/7. Don't know about now, but when I lived on the FL coast it was an expected part of daily life.<br /><br />I threw the BS flag because you made a blanket assessment of synthetics that made no sense. That you then clarified by specifying base stocks made even less sense considering none of us use base stocks, but only market products be they synthetic or dino. I personally don't care if folks use synthetics or not; they work for me and have for a long time. <br /><br />PAKev, most outboard manufacturers are giving synthetics a whirl; call your dealer and follow his recommendations.![]()
