bulldogtodd
- Aug 7, 2023
- 20
My old Johnson 40 hp electric shift keeps jumping out of gear when given throttle and its getting worse. Any suggestions? Thanks!
Excuse me for my ignorance but where exactly is this forward spring located if you dont mind me asking. If changing out the right lower unit oil doesnt do the trick Im gonna have to locate the spring next and part number. I appreciate all the help. TKS!No need to do any flushing , just fill with the premium blend.-----The issue is with the forward spring and clutch.----Stop running it and initiate repairs.----Easy fix in my opinion.----I developed a method to repair this about 45 years ago.
That helped alot racerone. Forward and reverse shift spring correct. Problem is could be corroded and need cleaning and possibly light sanding on the side the engages with the electro magnet. Am I correct on this assumption? Also im thinking by me putting the wrong lower unit oil in it could have corroded it and the magnets causing it to slip out of gear. Am I correct on my assumption? How hard of a job is this man? I think Im barking up the right tree now thanks to your guys help. My new oil should be in this week. I will report back. Thanks a ton for the help.Look for ---" top secret files "---on this site.----There may be help for you there.----I repair motors , know nothing about posting videos.
After watching the video Im assuming that the springs racerone is talking about are the ones on the driveshaft between the electro magnet and the gear forward and reverse? Im learning slowly thanks to you guys help. Tks!
Hey Jimmbo! This may be a dumb question but would it be beneficial to drain that bad oil and maybe fill it with something (alcohol) or something else maybe to get the rest of that bad oil out drain it and let it set and dry with plugs out before refilling with the good oil. Just a thought. Your the boat mechanic. Tks!The proper Oil is marketed by BRP as Precision Blend. It used to be called Type C. Be aware though, that there are some 3rd Party Oils claiming to be Type C, but are not Compatible with Electric Shift .
The proper oil is less Viscous than 75-90 gear, being that there will be some residual Oil left after draining, you will likely have to change the oil a few times to reduce the Contamination.
If the case continues to slip, check for damaged wires, You will need to drop the gearcase to examine the portion of of the wire that resides inside the exhaust housing(damage occurs if the engine is starved of water). In some cases the Hubs and Springs have become, best described as Glazed, and need a bit of cleaning. The system is simple in design and quite Reliable.
There is also the Possibility of the Switch in the Control due to the design, making interment contact as the Throttle Lever is sliding against it
