Intermediate Mariner
- Apr 24, 2010
- 190
Hey,
This is a good one.
Working on a '62 evinrude 40hp M#35530.
Am reassembling PH after rebore.
Have a 2-part question regarding the last steps on crankshaft assembly install before assembling crankcase.
I pasted 4 photos below.
Part 1: As noted in the photo of the parts diagram, there is a "carbon seal quad ring" that I gather goes next in line after the bearing. The motor that I disassembled DID NOT have this installed. When you ad the 1/8" thick rubber washer it extends the items closer to the end. This makes that spring awfully tight, almost pressed completely flat (you notice by the photo how I have about 1/2" of room). Am I on the right track? OR does the larger plastic bearing seal go next??
Part 2: I believe below the rubber quad seal is followed by a plastc "bearing seal". Both parts are different on each side. On the rubber seal is sort of a lip and a slight channel. On the plastic (hollow) seal there are 2 holes on one side.
Any idea the order and position of these??
Thanks Much-
Shawn T
Wichita, KS
This is a good one.
Thanks Much-
Shawn T
Wichita, KS
