Hello folks. I'm back with my too high oil pressure problem.
Ordered new oil pump/oil pressure valve assembly.
While setting new pump, found out a bypass release valve over oil filter fitting case.
Any clue about a bypass defect that could discharge directly into engine oil system ?
This will eliminate oil filter of the normal oil circuit , and eliminate oil filter flow effort, and could explain higher pressure.
Thank you, Paul.
Thank you, Paul.
