454 vs 454 Magnum
ericcarr2000
Ensign
I recently purchased a 87 Sea Ray Sundancer. The motor was rebuilt back in 2004 and I was told that it is the Magnum version, it does say Magnum on the flame arrestor. My question is this, what is the difference between the standard 7.4 and the 454 Magnum motors. Is there a difference in Horse power, and how can I tell the difference to see if I have the Magnum?
Mischief Managed
Re: 454 vs 454 Magnum
The last of the 454MAGs have 365 or 385 HP (can't recall) versus 310HP for the last of the "regular" 7.4 engines, not sure about your vintage. They used very different internals and the cylinder heads/intake manifold have bigger ports on MAG. The MAG is designed to rev much higher and is built to do so.
I suspect you have the regular 454 with 330 crankshaft HP.
ericcarr2000
Ensign
So I guess pretty much the only way I can tell if I have the Magnum version is to take the intake off and take a look at the head ports then?
tpenfield
The intake manifold would probably be the best way to tell as MM mentioned. The Magnums were known as having 'rectangular' intake ports, whereas the the standard 454 is commonly referred to as 'oval' port.
There may still be a serial number on the engine (look near the starter), and that could be more telling.
For the vintage that you are looking at (1987), I think the differences are 330hp for the std and 365hp for the Mag. Later models of the engine went more like 310hp for the std and 385hp for the Mag.
Usually you would see the 454 Mag on go-fast boats that can take advantage of the higher RPM. A cruiser would be more fitting for the std 454.
tpenfield
That serial number comes up as a 454 Mag w/ Alpha1, which was an offering prior to the Bravo outdrive introduction in 1988.
So according to the S/N, I do have the Magnum then?
Ayuh,.... Accordin' to the serial number, yer Lucky it's a 330hp, 'n not a 365hp,...
Alpha's done like that kinda power,...
Fun Times
Since your engine model was made in 1987 your serial number and the service manual and since the engine came in a sea ray, your engine model is a magnum but only rated at 330 HP and with one exception, Most of the engine internals should be cast aluminum for the 87 model, in 88 the magnums started using forged aluminum and upped to 365 HP. Studying over the links below should help you with some questions you may have.
Boatinfo - Mercruiser Service Manual nr. 9 - 1985-1988 - GM V8 Engines
Long Block Marine Engines, Marine Longblocks, New 454 7.4 Marine Long Block Engines and Rebuilt Mercruiser Long Blocks | Performance Product Technologies
Engine serial number 0B522432 is an MERCRUISER MAGNUM ALPHA 454 PARTS CATALOG 90-14296 - 454 MAGNUM ALPHA ONE ENGINE MERCRUISER - (454 H.P. (1987) Serial No: 0B522432 Model No: 04544347
Post #2,
Mercury Tech 454 magnum vs 7.4 litre Mercruiser
https://www.google.com/search?q=198...%2F210223-454-mag-s-build-ideas.html;1024;768
Walt T
Keep in mind 20-30 extra HP wont really be felt in that boat. I really do like those older Sundancers. I liked the teak they used to use.
ericcarr2000
Ensign
Ok so let me ask this, how much work is involved in changing over from Alpha one to a Bravo outdrive, do I have to replace the transom assembly?
ericcarr2000
Ensign
Do you think that the Alpha one would be able to handle a few more horse power, like maybe 10 or 15 more?
thumpar
Be gentle with the right hand. There is a reason Merc stopped that combo.
ericcarr2000
Ensign
Ok but if I were to ease into the throttle I should be ok though right? I rarely just hammer them anyways.
Ayuh,..... It's a BBC, with an Alpha drive,....
It'll run just fine,..... til it Don't,.....
tpenfield
Yup, but the good part is you can still brag to your boating buddies . . "yea, its got a Magum in it" :thumb:
alldodge
+1 with Bondo and will add
A buddy picked up a Fountain with a 600HP motor (Org motor was a 415HP). The boat use to belong to a high end rebuilder and he pumped the boat up to the 600HP blower motor. My buddy babied the boat and very slammed the throttles. The drive was a standard Bravo 1. The drive did finally give out and now it has a XR drive.
