470 4 barrel throttle linkage
Benny67
Does anybody have a diagram or part number for the coupling from the carb to the throttle cable for the 470 with the 4 barrel carb?
Specifically that pastic part that mates to the brass piece on the throttle cable.
I broke mine and attempted to repair it.Basically I patched it together but it sometimes causes the rpms to slightly rise on an idle so it's got to go.
I looked on Ebay but cant find anything probably cause I'm not searching under the proper terminology or do not have a part number.
Bt Doctur
Benny67
Thanks...I am starting to wonder if it was already rigged up before I got the boat cause the setup I have doesn?t resemble this. The plastic piece is much shorter.
