470 Starter (Pic) Does this Starter have a Starter Solenoid on the top?
yamhoss86
I was messing around with the Starter Solenoid from my 470 and i think i did something to it.
I have an extra starter (please see pic), not sure if this one has a Starter Solenoid on the top or do i need to order a new one. Thanks for all the help!
Bt Doctur
Re: 470 Starter (Pic) Does this Starter have a Starter Solenoid on the top?
the unit mounted on top of the starter body is the starter solenoid
yamhoss86
Thanks Bt, so i do not need another Starter Solenoid?
Bt Doctur
what were you messing with , and what did you do to break it?
osborne looney
If you are replacing starter i just went this way thru oreilly auto parts lots $$$$$$ cheaper from a 1964 intl scout l4 engine SAME STARTER !!!! 470 starter.jpg
ultima reman # 38-0831
you just have to change out rear mount studs from old to new for correct mounting pretty easy
yamhoss86
I was trying to clean the connections with sand paper, anyways i herd a crack when i finish tightening one of the connections. Went to go start the motor, The motor would start sometimes and would not start sometimes.
yamhoss86
If you are replacing starter i just went this way thru oreilly auto parts lots $$$$$$ cheaper from a 1964 intl scout l4 engine SAME STARTER !!!! View attachment 210404
Great, thanks.
I got my starter from Ebay for $80.00 (Including Shipping).
How much is yours?
Bt Doctur
the plastic end cap does not like being really cranked down.should be able to remove the 2 mounting screws, connecting bolt , twist and remove it.
yamhoss86
Ok great, i will just transfer the connections to the new starter solenoid.
osborne looney
i paid $ 64.00 with core but you got a good deal for the same thing i purchased
