470 trim pump leak
1977 SILVERLINE
Oil keeps leaking from this plug on my 470 trim pump. The plug is difficult to remove and I have changed the oring twice but it keeps blowing a chunk out of the oring and begins to leak heavily. Any ideas why this keeps leaking. Thanks.
ROY WILLIAMS
Oil keeps leaking from this plug on my 470 trim pump. The plug is difficult to remove and I have changed the oring twice but it keeps blowing a chunk out of the o ring and begins to leak heavily. Any ideas why this keeps leaking. Thanks.
the trim pump creates a higher pressure ...remove the trim cylinders on the outdrive .. then lift up the out drive is a very good movement or trim cylinders are looking the in/out buttons moving the pistons ..
then remove the oil,,,, tank see if its dirty ..many have to change the oil or leaks to get water in the oil ..
