Re: 4hp Johnson CDI Complicated Question
Joe:
Removed the spark plugs and hooked up a spark light tester. Cranked engine--no spark either wire. The power pack on engine now is new-purchased from the manufacturer. I have also tried a used power pack. The old pp, the used pp and the new pp all have the same fault-that is-120V out of pp to cylinder #1 (brown wire) 00V out of pp to cylinder #2 (brown/green wire).
Engine ran with no problems 'bout two years ago. It stopped and I: installed new fuel pump kit, new coil, and checked all wires and connections. It has never "fired" again. I searched for over a year until I found the new power pack 'bout three months ago. Still not running. All of the checks I have performed points back to the power pack, however, that is only this layman's opinion.
Thanx,
sailortoo
