your shift cable should not be moving once your in gear let alone at WOT
Agreed....but it was. Causing the shift interrupt switch to activate momentarily.
I’m not the first to see this BT.
That can ONLY happen if the cable is out of adjustment.. Or you have a fault in the remote control....
Chris.....
