spdracr39
- Aug 30, 2010
- 1,238
Well I thought it was a vapor lock issue and have been trying to repair it as such but now I am not so sure. Last weekend after running at cruise for a little while we stopped to swim. I didn't run the blower or let the engine idle and we swam longer than I thought we would. It was probably about an hour. The engine would not start back. We had to get towed in. The next morning on the muffs it cranked on the first try and purred like everything was perfect. I bought a fuel pressure gauge and checked the pressure it was 40 lbs.. When I hit the bleeder the pressure vented immediately and the fuel only flowed from the clear vent tube for a few seconds. All looked normal to me. We went back to the lake today. It was not hot outside at all. We cruised for a while and stopped. I did let the engine idle for 5 minutes and ran the blower for 10 minutes. I cranked it and it started fine so I turned the blower off and we swam about 15 minutes. Ready to go and no start. I hooked up the gauge and it would not make any fuel pressure. What was odd was that even with no pressure on the gauge if i hit the bleeder valve a constant flow of fuel would run through the tube and would not stop. I was draining it back to the tank from the fuel filler and I don't think it could have been siphoning because it was higher than the tank. Eventually after about 45 minutes it started back and ran fine. We just didn't shut it off again. What could be causing this ??? What is the pressure on the rail supposed to be? Why would it keep flowing from the relief when it won't build pressure but when it is working the flow stops when you bleed the pressure? Is there a pressure relief that could be sticking open when it is hot keeping the rail from building pressure? I am really grasping at straws now. Now that I think about it I never actually checked the pressure with the engine running I guess I should check that also.
