5.0 to 5.7 swap
Re: 5.0 to 5.7 swap
Ayuh,... It don't say what Vintage it is....
The distributer don't care, but the intake manifold cares which heads are used...
The heads you choose will determine if the manifold will fit...
stevehendo34
Re: 5.0 to 5.7 swap
emailed him to get year of this 350
What years will work in the 79 boat do you know.
Can you just use the automobile intake?
What other parts have to changed, freeze plugs,
What others ?????
Friscoboater
Re: 5.0 to 5.7 swap
I used a truck block in my Glastron which had a 305 and went to a 350. I had the freeze plugs changed to brass, a double roller timing chain, and a RV cam. I then used an edelbrock Alum intake manifold that was designed for torque. That boat jumped out of the hole.
26aftcab454
Re: 5.0 to 5.7 swap
fast SS.jpgand it looks like this
