5.0gxi-gf circulation pump pulley bolt size??
ingham01952
Volvo penta 5.0gxi-gf
I need to remove the circulation pump pulley. I’m hoping to find out the size of the bolts before I get there. Bolt serial number is 3863054
Please see image.
ESGWheel
Master Chief Petty Officer
I do not recall exactly, either ½ or 9/16 or a 12, 13 or 14 mm and I do not have access to my boat to check. What I do these days is take a few wrenches with me and try until I find a fit > it been a long while since I was working as a full-time mechanic and could look at a bolt and know the size (this was all pre-metric of course).
So, I gotta ask, why cannot you take a few wrenches (or sockets) with you to determine?
ingham01952
Thank you. it was a shot in the dark. I was attempting not to go all the way home to get my tools. I would stop and grab a wrench or two at the store. while I was handling something else I figured I would see if anyone knew. Worth a shot.
SBC water pump pulley bolts are 5/16-24
ESGWheel
that is a 1/2" wrench size if you were looking for that...
ESGWheel
Also, unless you have freshwater cooling, if you are replacing the circ pump be sure its marine grade and not automotive. See link
ingham01952
oh yes. i got all pulleys oem. this one pulley I want to save. water pump seal let go and coated engine in salt
