Hi guys. New to the forum with a slight problem.
I've posted on another site but thought I'd see what you guys think.
I've got a 1995 mercruiser 5.7 efi s/n 0F431832, Delco est ignition
So this season, end of last I couldn't get WOT and now only getting 3200 revs roughly, cant even get up on plane really. No real power at all, in fact since I've had the boat it's never been great.
Compression is good 170-180 psi, new fuel and pressure is 30psi, so it's not a fuel problem.
I checked for codes and got 42 so went through the diagnostic cheks in the manual, I wasn't getting the right ohms on the ignition module so got a new one but it hasn't helped and actually I seem to be getting worse results so might be a bad module I don't know, got another module on the way.
So I checked knock module today following diagnostic in manual and where I should be getting 8-10 volts I'm only getting roughly 4v. Are the ignition module and knock module linked or could I have a bad knock module also?
Also timing was at 12/13* BTDC so I've now put that at 8* btdc
Any input would be appreciated, can't seem to find anyone with same problem which is a bit strange!!
