5.7 GL volvo penta won't start
hman
5.7 GL volvo penta won't start. If I spray carb cleaner in and around the carb it will start and run fine until I let it sit for a while, then it will not start. This only happens to the port side motor. Any help would be great. This is my first boat::confused:
NHGuy
Re: 5.7 GL volvo penta won't start
Do you know how to set the choke for a cold start?
It's neutral on the shifter, two good deep pumps of the gas, set the throttle a little above idle, then crank to start. Engine should start if it's working correctly. Now if the choke is working the engine should run, maybe a little rough when it is cold. As it warms the engine should smooth out. You can check by removing the flame arrestor and looking down the carburetor, the choke plate should be closed on a cold start, then as you warm & rev the engine the choke will gradually open. When the engine is fully warm the choke plate should be wide open.
Check the obvious stuff. Fresh fuel & fuel filter? Or does that stuff share with the other motor? Is the intake manifold bolted down to the heads correctly and is the carb properly tightened to the manifold? If all this is correct is the ignition-tune up stuff up to date? If yes it's time to check the carb & fuel supply.
hman
Thanks: The boat did sit for a while with full tanks and i have replaced the fuel filter 2 times so far after i have refueled and I am still having this problem. choke is closed when I do try and start it. Could the float be sticking?
Ayuh,... If it's Not gettin' fuel, it could be Anything in the fuel system....
Don S
Could be a blown fuse or circuit breaker for the fuel pump, a bad relay, blown diode, or poor connection, not allowing the fuel pump to run while you are cranking the engine.
What is the full model number of your 5.7GL, should be letteres after the GL.
hman
Thanks: When I go to the boat tomorrow I will get the serial #'s and post them
