5.7 GSI distributor cap
Lubak572
Does anyone know the tap size for a distributor cap bolt? I had 2 bolts break off the stock caps, They were a pain to remove but i did it, Now I would like to chase the threads before i put the new cap and rotor on it. What is the bolt size thread pitch. Also will put a little antiseize on the new bolts.
Ayuh,..... Don S convinced Me, years ago, that form-a-gasket #3, which is Quicksilver Perfect Seal, Works Soooooo much better than never-seized ever has for such things,......
I donno which distributor is in yer motor,.....
Do ya have the full alphanumeric model/ serial number for it,..??
I'd Guess, probably a # 10, or # 12, fine thread, unless it's metric,.....
alldodge
I believe they are metric. the EST distributor is the same. I really need to write this down, but one of my mine was stripped, so I had to tap it out to the next size. Memory isn't very good but think it was M4 screw size up from M2
Never use always-sieze on a marine motor
The graphite in anti-sieze promotes corrosion in aluminum and steel when exposed to salt water. Put it on a stainless bolt in an aluminum housing in a marine and you will not get the bolt out....
Galvanic corrosion will fuse it all together
Lubak572
FYI- it was an M3 X 5 tap. Also I am in freshwater only.
galvanic corrosion doesnt care, its just slower in fresh water. if you want something to use on the screws, use tefgel or permatex #3
