I just bought a 1998 Sea Ray 230 BR with the 5.7 L EFI, Bravo 3. I noticed that it intermittently will idle at 1200 RPMs. This occurs AFTER I have started and driven the boat. The only way to "fix" the high idle is to turn off the motor and restart it. Then it idles at 600 RPMs. If I drive it again, it may or may not again idle at 1200 RPMs when I place it back into neutral. Again, it "fixes itself" when I turn the motor off and restart.
I searched the forum and found a post from two years ago by someone with the same issue. I tried PM'g him and haven't heard anything. He did a lot of work trying to fix the issue and the thread ended without a resolution.
I will paste his post below:
"5.7 EFI High Idle
Don or anyone - hoping can help?.
1998 EFI Serial Number 0L025442
Developed high idle issue last couple of years. Doesn?t happen every time. Worked on it last summer - got boat out of storage this spring - put in a new TPS and still happening.
Symptoms: Start engine ? idles normal (600 RPM). After 20-30 minutes of use ? shift to neutral and idles high (1200 RPM). Now interesting part ? simply shut off and re-start and it idles normal.
It?s the fact that shutting off and restarting ?solves? the problem that is causing the real head-scratching.
I have worked with a Merc mechanic on it.
We hooked up to scan tool. No error codes. Only unusual reading is the Throttle Position reading ? sometimes at 0% but sometimes at 2%. (Normal range according to Merc is 0%-1%).
In full disclosure: The only other issue is the Tachometer on the boat sometimes is not working or running backwards. If I understand correctly the tachometer and shift interrupter switch are on the same circuit.
Actions:
The Merc mechanic is hoping to get in touch with a specific ?older? Merc Regional Field representative who is familiar with the older MEFI I systems. He talked to a younger guy in Fond du Lac but didn?t seem as up on the older EFI system.
Merc mechanic thinking of replacing plugs and/or spark plug cables and check compression. His thought is that maybe the ECM is able to correct for bad plug but it shows up at idle. Alternatively, he thinks the ECM is going bad ? but I would think we would see lots of other issues if this was the case. He admits that is unlikely the problem but simply running out of ideas.
Any ideas?
Any suggested diagnostic process?
Makes for alot of fun docking - when idling too fast and can't shift into neutral/reverse. "
So, does anyone have any ideas on what this might be or how to best approach it?
Thanks,
Bill
"5.7 EFI High Idle
Actions:
- Cleaned throttle body
- Adjusted the cables even though seemed fine to begin with ? now really solid pressure pushing the throttle plates closed (Throttle Position still reads 2% on scan tool sometimes)
- Replaced IAC
- Replaced TPS (Throttle Position still reads 2% on scan tool sometimes)
- Replaced PVC value
- We hooked up a temporary bypass for the shift interrupter switch.
Any ideas?
Thanks,
Bill
