Lou C
- Nov 10, 2002
- 13,066
Just for the heck of it I pulled my old intake manifold out of the garage today. Waiting on the machine shop to determine if the heads are still good enough to make doing a valve job worth it. The intake is fine really. In the water passage just below the thermo housing, there was flaking rust but just a thin layer of small particles that easily scraped off. Not big chunks or hunks of rust like you get from an exhaust riser. While I still would not try to put closed cooling on an engine this old, even if you ran your raw water cooled engine as it is, it would be years before you'd have a problem due to corrosion as long as you change that exhaust system every 5 seasons. On mine as long as I have had it (since 2002) when I winterized it I always filled the engine and manifolds up with the best -100 marine antifreeze with corrosion inhibitors. I really can't say if this helped having nothing to compare it to, but maybe so. So check the inside of your intake and post up some pix....
