- May 16, 2009
- 9,260
Re: 5.7 TKS will not rev under load
Do you have a timing light and an extra person to drive so you can watch and see if your timing will advance? Check the wires to the module as well.
Good luck.
At least you tried.shift interrupter switch seems fine- in gear it is right in the middle of the "v", and disconnected makes shifting very hard. dang- i was hoping that was the issue and an easy fix!
Good luck.
