- Mar 8, 2009
- 43,218
The injectors should be the same, the amount of fuel is controlled by the ECU. Pull the connectors off the ECU and check for bad connections (+/-). Your ECU might be the issue but guess it could also be a bad connection,
Just found some more notes I made on these motors. Which GXI do your have?
Would post a pic but there is still an issue with IE 11 :facepalm:
Reason for asking for 5.0
GXI-A fuel pressure high side is 29 +/- 2 psi
Timing 8 BTDC
GXI-B,C,D,E fuel pressure high side is 50 to 60 +/- 2 psi
Timing 10 BTDC
Timing 8 BTDC
Timing 10 BTDC
