Bl@ck Pe@rL
- May 17, 2009
- 11
5.7L '07 Merc - Coil Arching -> Coil/Distib/Roto Replaced & Still Arching: Next Step?
Due to a coil arching problem (arch between term wire and coil to distrib cap wire) I replaced the coil, distrib cap and rotor on my port 5.7L 2007 Mercruiser on '96 Proline. After less than an hour of run time, the arching is back.
I have pulled the coil-to-distrib cap wire off the stbd motor (which runs) and still have the archning, from what I have read, sounds like my next step is to check/replace spark plugs and spark plug wires.
Looking for a "warm-fuzzy" that I am on the right track. One other variable in this is my raw water washdown tubing and live-well tubing is directly over this Port motor and I did notice some drips from this tubing down on to the motor. And we were running the washdown and live-well when the motor shutdown after the 1 hour of run time.
Thanks in advance!
Jon
Thanks in advance!
Jon
