StevNimrod
- Dec 13, 2008
- 343
I wrote a nice long post and it got deleted (beginner's luck, I suppose), so here it goes again...
I have a 1994 Wellcraft Excel 26SE powered by a 5.7L carbureted GM motor. The motor serial number is OF276159.
I'm considering getting my hands on a pair of the 906 Vortec heads (with matching intake) and doing a swap. Are there any issues I should be aware of in doing this?
The previous owner told me that the guy he bought the boat from did some engine work and made it a "roller" engine. I've called a few local shops and there is some dispute as to whether or not this is even possible on this motor. Is it possible or not? It's hard for me to tell on the phone which shops know what they're talking about and which don't. I also would like to know if there is any way for me to find out what cam this guy put in, or do I have to pull it out? I figure that while I'm doing the heads I might as well...or maybe the engine will get pulled and I can do it in the comfort of someone else's garage.
Also, I've been reading a bit about having to modify the rocker studs (changing them from press-fit to screw-in) and keeping an eye out on the lift, etc. Anyone have any experience with how big (or small) of a PITA this type of stuff is?
One more thing...
I can currently turn the engine up to 5200 RPM (based on the tach on my timing light, not the dash tach) with a 15.25 x 15 3-blade aluminum prop. I don't know if this was the idea of the engine build from two owners ago, but it got me thinking that either it's underpropped or he built it like he was building a car engine (top end HP rather than low end torque). There is also a Stainless Marine thru hull exhaust system (manifolds/risers/etc) installed as well as an Edelbrock Performer intake and I can still only get 32 MPH at WOT vs. the 38 MPH advertised in the boat's owners manual. I'm not a speed junkie by any means, but thought it suspect that all of these add ons have lost 6 MPH. Is this even possible, or did someone get it wrong somewhere along the way?
As an aside, there is a faint white smoke trail out of the thru hulls at WOT or when I accelerate hard, but the smoke dissipates rather quickly. I also leave a small fuel sheen on the water at the dock when I first start the boat up to leave my slip (but not when I come back in at the end of the day and let it idle at the dock). I'm not burning oil (or otherwise consuming it), and I'm fairly sure the sheen is fuel (smells rich). Compression numbers are all within 10% of each other or so. I don't have the actual numbers with me, but from what I recall they were all in the 140s range. Any ideas on what the culprit could be (I recognize that "a million different things" is probably one correct answer, but I'm looking to get a few knee jerk responses on what it could be based on experience)
Lastly, how much time can I expect to tie up doing the head swap? Are there any other parts I'll need, so I have an idea of how much I'm going to get nickel-and-dimed?
Sorry for the long, rambling second attempt at posting, and thanks in advance for your input.
One more thing...
