Hi all,
I have a 5.7L Mercruiser with a water leak in the bilge when running. It’s a small leak and the bilge pump handles it, but it’s not ideal. Only happens while the engine is running, then drains out for about 8mins. It looks like it might be coming from what should be a drain plug? However they’re appears to be some sort of quick connect system rather than a simple plug. This is on the starboard side, same side as the gear lube.
I’m not sure how I would tighten this down… as it seems to be coming from the connector itself, not necessarily where it threads into the engine. Any thoughts?
