Okay so I spent all day Friday putting the engine back together. New head gasket, valves adjusted, new water pump impeller, new thermostat, manifolds and risers checked for true and clean mating surfaces. Reassbled everything with new FelPro gaskets (except for OEM riser gaskets) and carefully torqued to spec. I also reinstalled the distributor to the mark for #1 cylinder.
When I tried to start it this am it turned over but would not start. I was getting spark but I don't think I am getting fuel. I had to leave so wasn't able to do much troubleshooting. The engine is a 1996 5.7LX Efi 250 hp non-vortec It has a mechanical fuel pump, a VST and a throttle body. When I removed the VST I lost some gas out of it. Does the fuel system need bleeding?
I understand that a Mercruiser scan tool must be used to set the base timing on this engine and you cannot connect a purple/white wire to ground and use a standard timing light as on some models. If that is the case I will need to have the service department do that and I will have them check why its not starting too. They are still very behind and it will be "a while" before they can look at it and summer is marching on :facepalm:.
In the meantime does anyone have suggestions for troubleshooting?
Thanks
Thanks
