I have checked many items for many problems. Yet the motor runs rough and is hard to start if I pump the fuel bulb. If I don't touch the bulb it starts but still runs rough. I tried adjusting the carbs with no luck. Things I have done and checked.
Replace float, needle and gaskets in carbs, repaired wire from stator to rectifier, replaced rectifier (ohm tested bad), replaced spark plugs, ohm tested coils-stator-trigger all good. Repaired dried out cracking wire for trigger. Replaced impeller. Installed a new seal for water plate cover that was leaking out by the #1 cylinder.
I planned on checking the timing but it was raining tonight. Hoping for some good luck and good weather.
I have had a few threads previously with some great help. Lets keep it going and get this old beast running! :joyous:
I also replace the fuel lines in side the motor cover and the compression tests at around 115psi each cylinder . Choke plunger replaced.
Serial 6486874
Serial 6486874
