kalebsheridan
- Aug 14, 2023
- 222
No I haven't. What would that do?
A faulty rectifier can cause the ignition-system to misfire at high-speedNo I haven't. What would that do?
Oh okay cool. Didn't know what rectifiers do. I will try disconnecting it and see what happens. Now it only misses while revving down. Revving up it's super smooth. I was running in a test tank without the prop. I know it's best to use a test wheel but I don't have one. I'll have to get it out on the water and do a test run for sure. I think it needs to be run pretty good for sure. Lots of blue smoke, and when I had the PH off there was so much sludge in the exhaust system. Do fuel pump diaphragms get worn out? Or just tear and then need replacement?A faulty rectifier can cause the ignition-system to misfire at high-speed
Are you using the correct spark-plug that this engine is prescribed?
Are you running this on muffs or in a test tank in gear?
Ideally it would be best to run it on water full tilt for a bit to clear/clean the whole system
There's your answer! running it without a prop will make it sound like a misfire! put a prop on and it will not sound like it.Now it only misses while revving down. Revving up it's super smooth. I was running in a test tank without the prop. I know it's best to use a test wheel but I don't have one
They can tear that's an easy check (although I'm not familiar with your engine)Do fuel pump diaphragms get worn out? Or just tear and then need replacement?
I think........it is because there's no resistance/load whatsoever on the motorFrom my experience it will arise more at 2 cylinders then 3 or 4 cylinders.
Maybe some other can chime in at explain more why it happens.
Oh okay awesome! So my engine must be good to go then that's been my only problem up to this point. How did my idle sound in that video? Because Ive never owned a properly running force, I don't know how it's supposed to sound. Oh okay I gotcha. I checked my diaphragm and it looked stretched out. The new ones look perfectly flat.There's your answer! running it without a prop will make it sound like a misfire! put a prop on and it will not sound like it.
I think mine is a cross flow? Not sure I'll double check. Okay sweet yeah that makes so much sense. I'll get it out on the water in a few weeks and see how it does. I tried not to run it too much without the prop too, I can't imagine that's good for the motor. Yup my diaphragm was still and stuck in a dish shape. I will order a new one. Sometimes the motor sounds like its getting pauses in fuel delivery.Yes as The Force power says when throttling down when running in a tank and without a prop some two strokers can behave like it is misfire.
I think it depends on if it is a cross flow engine or a loop charger.
Check the fuel pump diaphragm and change it if it is stiff.
The 50Hp use the same diaphragm as the larger 3 and 4 cylinder engines.
Actually it has the same fuel pump as the 3 and 4 cylinders.
The 140 and 150Hp Chryslers had two fuel pumps.
The diaphragm is cheap and you can buy a kit with the gaskets included.
Did you check the passage behind the screens? verify if there not pluggedAlso, I did check the recirc. Had some junk in it but symptoms appear to be the same
Behind the diaphragms?Did you check the passage behind the screens? verify if there not plugged
No, behind the screens from the recirculating.Behind the diaphragms?
But it is my felling and experience, no scientifically conclusion behind it.
ANYTIME!!! you have a miss you should do the starting fluid test.
Start the motor, spray starting fluid around the intake side .
This includes under the coil/pack bracket the carb bases and around the port covers.
If the spray makes any difference?? then it's got a bad gasket and sucking air
Oh okay I see. Yup I cleaned the recirc plate thoroughly. I had to take the PH off last week to replace the exhaust gasket so I did it then. Lots of junk in my recirc, especially in the screens. Are there any check valves beyond the reeds that I should be concerned with? I tried blowing and sucking air through the tubes after the recirc plate and I could just about get air both ways.No, behind the screens from the recirculating.
Carefully remove the screens and you'll see a tiny hole, poke with stiff wire through or blow compressed air through
