50 pounds over the max
Status
Not open for further replies.
hungupthespikes
Master Chief Petty Officer
Re: 50 pounds over the max
Most 5000 lbs. trailers have 2" ball standard. Thats only good for 6000 lbs. total (boat, motor, trailer and all the fluids and gear). If your trailer is a 2" ball you could be, way over the limit and will have to change coupler along with the rest of the upgrades. Be safe and good luck.
dingbat
The diameter of the ball in it's self is not a good indication of it's towing capacity.
Ball size
(inches) Bolt diameter Capacity pounds
1-7⁄8"
?″ #2000
1″ #2000
2"
?″ #3500
1″ #6000
1?″ #6000
1-3⁄8″ #10,000
2 5⁄16
1″ #6000
1?″ #10,000
hungupthespikes
"The diameter of the ball in it's self is not a good indication of it's towing capacity."
dingbat, your right and I stand corrected, thanks.
Just a 5000 lbs. trailer and 2" ball should raise a red flag. Something else to look at before spending the money to upgrade the trailer.
bruceb58
thanks guys it worked out fine ..she pulled just great .
Not sure what pulling great has to do with not being overloaded. You are risking your life and the people around you using that trailer.
The boat weighs 5050# dry
100 gallons of gas is 600#
40 gallons of water is 320#
300# gear
1000# trailer
You are at a total of close to 7000# easily if not over and you have a trailer that is rated at 5000#. How do you not see this as a problem??
kenmyfam
300# gear
1000# trailer
You are at a total of close to 7000# easily if not over and you have a trailer that is rated at 5000#. How do you not see this is as a problem??
Have to agree with this one !!!
e10
Why don't you get the boat and trailer weighed and then you will be able to make an informed decision whether it is safe or not.
maccustom
some of you guys on here a little much for me..some of your comment are useless, no help why are here? thanks e10 will do
waterinthefuel
It's called someone with more experience commenting on the behavior of someone with less experience.
It should be a lesson learned, but some are more hard headed than others.
maccustom
well with experience come grace, you just dont say the 1st thing that comes to mind because you would like it to be be taking in postive mater.. who would take neg as pos..pos should be 1st and always
180shabah
why respond ? hows does this help
how is anybody helped by having another grossly overloaded trailer on the road being pulled by a driver that is grossly overconfident???
AMEN!!!
maccustom
well i dont get it, are yal mad it work? there are so many other thing that could made it work .. i thought you guys knew more than me thats why i asked, i guess i was wrong you know no more than me. thanks anyways happy boating !!!
doug3297
Hey Mac, I just read all thru this and basicly everyone said that from your information, the trailer was not rated to tow your boat unless it was for a very short trip! Then you blow all that off and doit anyway. Why ask for info when your not going to listen to it? Kinda sounds like you wanted some to say "Sure it'll work go ahead". If it did tow great then weere all gald youmade it without having a problem but how times you going to chance it? These guys are here to help but if your not actully going to listen then dont waste peoples time.
LippCJ7
Sure we can be short and blunt but its still up to you as to what you decide to do Mac Good Luck with whatever you chose.
kenmyfam
If you don't like what you hear then don't post in the first place.
Simple as that !!!
Cadwelder
I really don't understand some people...:confused:
Status
