50HP force engine starter problem?
yellostrat
I have a 50HP force outboard that doesn't want to start.<br />With fresh battery I experience the following:<br />Turn key and starter engages but will not turn engine over, IE; lugging<br />Re,move plugs and it spins well.<br />All connections appear good.<br />Starter becomes hot(very) aftera few attempts to start.<br />BAD starter?
JB
Re: 50HP force engine starter problem?
Yo, Yellostrat. My first reaction is a poor connection in the high current circuit for the starter. Sometimes they can look good but have some corrosion between the connections. I would eliminate that possibility completely before I got into the expense of pulling, checking and maybe replacing the starter motor.<br /><br />Good luck.<br />JB
12Footer
Just to add to what JB said, yes the starter could need rebuilding or replacement if the connections all look good. Try the "screwdriver trick" too,before pulling it. Take a heavy screwdriver,and jump the high-current side of the solenoid.
