Re: 50hp forse marine power qoutboard 1989 need help- ignition switch
The woodruff key is a small, half moon shaped piece of metal that fits into a slot on the shaft....and a slot on the flywheel. Theoretically, the flywheel can only go on the shaft in one position this way. Without that key in there, the flywheel will go on....but your ignition timing would be way, way off.
Do you have an ohm meter? If not, you'll need one. WalMart has them for around $10-$12. The trigger wires are in pairs, as are the stator wires. You want to find resistance on each pair. (Check the manual for the correct resistance.)
