hi I was wondering if anyone had any ideas on a problem that i am having with this 50hp mercury motor. the motor starts on choke but will die out soon if throttle isnt given . i cant put motor in gear until motor has warmed up for a couple of minutes (warm or cold) or it will stall. you also can tell by the sound of the engine that top end speed is not achieved. I took out plugs and they look wet.is carburator work needed or could it be timing? thanks alot for the help
