Egret189
- Apr 6, 2011
- 13
Hi, everybody.
My weird long-time fantasy boat build has been a home-made high performance pontoon boat. Recently I've decided that this is a project that I'd like to pursue. Maybe you folks can send me some wisdom or have tried to do something similar.
THE PLAN:
A) To find a ~20ft pontoon with the larger style pontoons with or without an engine. Probably mid '90s is the era I'm thinking. I've owned a few Sun Tracker "Bass Buggy" 'toons and think that it would make a good platform.
B) Find an aluminum welder to add reinforcements wherever needed. I am thinking the engine mounting bracket would be a good place to start. I would also then have him add planing strakes as are found on the newer pontoons to add some planing capabilities. (The hydrodynamics involved here may be where you can help me).
C) Mount an engine profoundly larger than that for which the boat was designed. The engine I have in mind is a 150 or 175 Johnson Fastrike (60* Block). I really like these engines for power/weight ratio.
With all of this completed, I am hoping that the end product will be a somewhat cheap pontoon boat that is capable of cruising at 30mph or so. My family loves pontoon boats for the room and comfort but the rate of travel leaves much to be desired. I know that I could buy a deck boat but that sort of ruins the novelty for me. I realize that this build would involve a decent amount of modification to the pontoon boat itself. I just want to know if I am overlooking anything crucial to the success or failure of this endeavor. Thanks for any and all input!!
Jake
THE PLAN:
Jake
