tamarackstyle
- Apr 4, 2002
- 45
Ive just purchased a 18' starcraft, and filled her up with water yesterday to check for leaks. Ive got a small one from corrosion and a couple from rivet repair gone wrong,and a third from sealant failure at the keel. My thoughts were to plate the corrosion with 1/16, repair the rivets with machine bolts and run a new bead of sealant along the keel. I will be using 5200 for all the repairs and was wondering if, for adhesion, at what stage would it be best to apply. Bare, zinc chromate primer or finish primer? Thank you.
