I have a 1969 55hp evinrude. I took it out on the water today and it started great, shifted great and away we went. The only thing is when it was on full throttle, for 55hp it seemed to be moving not nearly as fast as it should. I turned the boat around and as it turned the boat slowed way down, I mean way down and the throttle was open all the way. Then I straightened out and the power slowly came back. I've cleaned out the carbs, put in new fuel lines, I run 50:1, I adjusted the carbs to run a bit lean to clear up the exhaust, but should I get it adjusted at a mechanic? could that be it? Also somebody suggested it's because my lower leg is a 15" instead it should be a 20", he said that's probably why it had a lack of power. The stabalizer fin is about 3" above the bottom of the boat, but the prop is way under the bottom.<br />Any thoughts on what should get done, or what I should check? thanks
