Rick K
- Oct 6, 2003
- 235
Been having a problem with spark on my lower cylinder. Engine starts right up (half a pull and she starts to purr...), runs beautifully, can't get WOT however. Pulled the lower wire, she keeps running. Pull the top wire, she dies right out.
When I pull that lower wire, I do get a nice blue spark jumping from the wire to the plug, but not really enough it seems.
Replaced the coil front coil this evening. Other coil was replaced last season. The old one was the original, and had alot of goo, etc., on it, so I figured that'd do the trick. No go...
Compression is right up there, full tune up, etc., least season, with new plugs this season. She ran absolutely perfect until this.
I did read up on Saskatoon's issue where he couldn't get to WOT, but I'm thinking that my problem is not as in-depth as his. I can't believe the motor would run perfectly, then just start this s**t.
I did rebuild the carb, but have ruled out the fuel system with the engine dying when the top wire's pulled. Ran great with the rebuilt carb anyway.
Other than switching the coils, does anyone have any ideas?
Thanks!
Rick K
Thanks!
Rick K
