5'x12' MG plywood??
ondarvr
Re: 5'x12' MG plywood??
Are you ready to pay the price?
ondarvr
Any lumber yard will special order it for you.
MaddysDaddy
whata think it will cost i got a pirice of $70 a sht for 1/2 4x8,(i need two sht) with the 5x12 i only need one sht
ondarvr
You'll need to call and find out.
A list I ran across.
Allied Veneer - (Nationwide) 800-540-7040
Almquist Lumber (CA) - 707-668-5652
Atlantic Plywood (Northeast USA)- 800-937-6700
Boulter Plywood (MA) - 617-666-1340
Chesapeake Plywood (MD) - 410-244-0055
Connecticut Plywood (CT) - 860-953-0060
Crosscut Hardwoods (OR, WA) - 503-224-9663
Houston Hardwoods (TX) - 800-606-6176
MacBeath Hardwoods (CA) - 510-843-4390
MacBeath Hardwoods (UT) - 800-225-3743
McEwen Lumber (NC) - 800-662-7468
PlyTac (WA) - 800-468-6848
Rare Earth Hardwoods (MI) - 800-968-0074
Riverside Lumber (LA) - 800-669-6624
Roberts Plywood (NY) - 631-586-7700
Russell Plywood (DE, MD) - 800-787-7355
Whittelsey Wood Products (FL) - 305-621-4242
West Wind Hardwoods (Canada) - 800-667-2275
Cadwelder
The Plywood Mart here in Charlotte can order the 5 x 12 1/2" and I know these guys so I called them. They sell good stuff, but aren't know for cheap when ordering a few sheets at a time..Anyway he priced it out for me at $215.00 a sheet. Why do you need the 5 x 12 size?
MaddysDaddy
the sht that came out was 5`x8` so thats where the sringers are at and i dont wanna run other way will make 3 seams that where it failed at the seam. so i would rather not add more seams. 12 ft will get me to the bow struture in one piece
Cadwelder
I see your point, but if the seams are glass properly you shouldn't have the problem again. I've seamed plenty of them with no problems, as have plenty on here I'm sure....
But your choice, want you're looking for is available.
Woodonglass
I agree with CadWelder, Seams are NOT an issue if done properly. Factory seams are so-so. When YOU do them YOU can make sure they are done correctly and you should not have a REPEAT of the failure.
jasoutside
Yah, I am with these guys. Save yourself some cash and just seam your deck. You can always use the scrap for hatch boxes and such. Just do yur best and sand it flat, eh!
rickryder
I noticed that where my seams were on the Four Winns they ran a strip of ply from stringer to stringer level with the tops of the stringer for the deck to sit on. I can only guess it was to support the seam.
