6/8/9.9 differences
bbstacker1
On the early to mid 90's, 6/8/9.9, what are the differences to increase/decrease the horsepower. This is referring to 2 stroke motors only
jimmbo
Exhaust, Port Timing, Compression, are some of the other potential variances
the 9.9 is a bigger displacement than the 8hp since the 9.9 shares the block with the 15
bbstacker1
Later in the series the block was the same for the 9.9/15, the earlier ones, the 6/8/9.9 shared the same block with the 15 being different.
1985 and earlier 7.5 and 9.8 shared a same block. 1986 and later the 9.9 and 15 shared a block, the 18-30 shared a block and the 6-8hp shared a block.
QBhoy
As said. 6 and 8 are the same. 9.9 and 15 bigger and the same as each other. Significantly heavier that the 6/8 too.
