marshmaster
- Apr 3, 2011
- 16
i have got an older 6hp johnson, model number tag missing. After rebuilding the carb, setting the points at .20 and re assembly the motor does not start, the same as before rebuild and general go - over. When I installed the timin plate I rotated the plate so the points were open in line with the word "top" on the cam that operates them at their widest point. I have spark on both clyinders. Adjusted the float as well. I got a feeling I am missing part of the equation somewhere. With a quick fog of ether it will fire and seem to run well except when I turn the tiller to slow as it will go then dies out. When I purchased it from my buddy he said it konked out and never acted right since. Is there a way "adjust" the timing or any other ideas on what i may be missing. I know this seems lengthy but I want to provide all info. and reapirs attempted, to get the best ideas. Thanks in advance.
