65 6hp gear case problem
Parrothead71
The locating pin in the upper section got either pushed in or beat to a pulp when I had a problem a couple years ago.
I'm looking for some ideas on how to remove the pin to replace with a new one.
F_R
Are we looking at the dowel pin that locates the bearing? Drill a small hole in it, thread the hole, screw in a screw, pull the screw and pin out.
Parrothead71
Yes that's the pins. I thought about that but I am thinking the pin is hardened.
Drill it out as stated.-----You may find that this pin LOCATES the bearing for proper lube flow.------Not really critical if you position that bearing properly before closing it up.
Parrothead71
No Title
Good thing I work with some pretty talented welders!
