Re: 65 hp Evinrude died and won't restart
Your engine has three coils - having all three fail simultaneously would be unlikely. I would suspect either a failing powerpack or shift switch. Start it on the muffs and "rattle" the key switch. If it won't run on that attempt, still "rattle" the key switch. If it either quits running or does run after an initial failure, the key switch is probably the problem.
You can also do the "key switch test." Disconnect the black/yellow wire at the #6 terminal on the powerpack and use a spark checker to observe spark at each of the spark plug wires. With the black/yellow wire disconnected, crank the engine with the key switch. If you get spark on all three cylinders, you have bad wiring somewhere in the harness (black/yellow circuit), or you have a bad key switch. If you get no spark, or spark on one or two cylinders, you most likely have a bad powerpack.
