67 Year Old Head Bolts
Crosbyman
I use my hammers. It’s all the other tools I’ve collected over the years.
Have a hard time passing up quality tools at a bargain whether I’ll ever use them or not.
A boxed set of Starrett precision machinist squares from a guy down the road for $3.
A full set of Snap on, 1/2 and 3/8” drive torx bits at a local thrift shop for $6
A 12” x 12” granite surface plate for $20 at a flea market.
Unfortunately. I could go on and on…lol
just make certain your estate is willed to someone who will appreciate your quality tools otherwise they will become bargains at a local thrift store again. !
tphoyt
That’s more than likely what will happen to mine. My kids didn’t follow the handyman path.
Maybe my son will keep some stuff but I doubt it. I’m sure he will get top dollar though he’s a great businessman.
rolmops
some guys have all the luck
LaqueRatt
Got the replacement head cleaned up and ready to install. Gasket showed up a few hours ago. Found a NOS OMC gasket that retails for $42, on ebay for $13! Today smacked the bolt heads a few times with a drift pin and a ball peen and then soaked them with PBB. I can't imagine much if any making it down to the actual threads though.
Going to try to get the head off tomorrow. I'd apply some heat if thought it would do any good. Those threads are pretty well protected under the gasket it seems. Heating up the entire power head with a torch seems a bit futile. Wouldn't the alum just act like a big heat sink and bleed the heat away right quickly? I only have a medium size torch set. Not a big one like a real shop has.
tphoyt
I wouldn’t over think this until you have to.
They may just come out as they should. If not then start ramping things up as needed.
Crosbyman
sorry for not backtracking.. if compressiion is OK I would not mess with the bolts... if you want to "see" inside get a cheap endoscope on amazon.
Mc Tool
Even heating and cooling a few times can help the pbb to wick its way in . Heating the side of the block where the bolts go in helps too .
Patience is a real bonus here, sometimes you have to persuade on a bolt for a few days of overnight soaks and heat cycles and hammers to get it to see things your way .🙂
LaqueRatt
Yes, the plug hole is stripped. While adjusting the carb it died and wouldn't start. I pulled the plugs and the one came out along with the threads from the head. Argh! I don't even know how that could happen. My attempt to put in a threaded sleeve didn't work, so now I'm stuck replacing the head.
It's going pretty much like I figured it would. 3 of 10 bolts snapped even using PBB, wax, heat, and banging on them first. I forgot to pray though. Maybe that's where I screwed up.
Was able to get the two snapped upper bolts out, but the lower one that is pretty much impossible to drill won't come out. The stub was too short for vice grips (of course!) so I cut a slot in it and did my best to wiggle it out with a screwdriver after heating it as hot as I could. Now half of what is left broke off. What do now? I've heard you can weld a nut on, but never actually tried it. Guess that's about my only option now except for pulling the power head or maybe.......drilling a damned hole through the housing so I can get a drill with a long bit in there?
I know nobody will like this idea, but what if I just left that one bolt off? Any chance it would still seal?
LaqueRatt
One more thing. Maybe this is a contributing factor in why the bolts are seized up. The parting line between the head and motor has a lot of paint coming off. Does this indicate it got really hot maybe? Or just a sign of age? Seems odd to me.
saltchuckmatt
Corrosion and rust from age or abuse really. You have a tough project ahead of you.
I purchased an inexpensive 120 volt stick welder just for removing said bolts. Stainless stick rod, stainless nut and I drop it in the middle and puddle it in. Takes some practice but works very well.
Looking at your work, I'd say you didn't hear it enough. I have to turn the knob in my brain that says heat and patience and that switch doesn't always seem to work!
When I pick up older motors like that , they come apart for full inspection BEFORE spending any coins on parts.---Powerhead and lower unit.-----There is usually something wrong internally !----Easy to drill out broken bolts on a drill press.----Should be easy to find replacement parts for these as well.
Note----The HELICOIL repair kit that I have repairs that stripped hole WITHOUT removing the cylinder head.---Easy repair for me.
Crosbyman
options options but pulling the head isn't that hard to do , you can clean out built-up carbon in the exhaust section :) , drill out that bolt unreachable bolt. etc,,, I have done the solid heli-coil thing with success (don't like/use the spring type) or swap head
LaqueRatt
I agree, probably could have used more heat. I could not get it cherry red. I don't know if that's really possible with alum, is it? Did all I could do with my little torch which generally works well on steel.
For welding I have a pretty decent wire feed. Guess it's worth a shot, but not feeling lucky today. How do you keep the nut in place while filling it up with weld?
I did not use a helicoil for the repair, got a solid sleeve insert. Not wanting to spend big bucks on a $60 motor, I bought a cheap kit which I think may have had mismatched tap and insert threads. With no spring or tang, I installed the sleeve with Locktite and used Never Seize on the plug. Figured once it set up just the plug would come out. Nope, plug came out with insert turning into a spring anyway, and pulled even more alum out of the head. How does that even happen? It's like the alum is brittle or something. I tried to reinsert the whole mess and it never got really tight. Motor actually started and ran, but I knew that plug would just blow out eventually.
Think before I try removing the power head I'm going to bolt it together with only 9 bolts. If I do have to remove it, I see more busted bolts in my future. They've just been in there too damned long.
dingbat
Mc Tool
Aluminum doesn't change color when heated.
The first indication that your too hot (~660 C) is when the over heated area drips to the floor
😁Ha ha , yeah dont worry bout the paint burning off....that don't mean nothing😆, but yeah ally can be hard to "see" the temp . If in doubt use an ir thermometer and dont go above 120⁰c
