Actually I repaired a bad connection in the tank fuel line, & it runs much better....
It will idle & shift just fine.....
I still have not done a compression test, because it just started to pour here.....
It will idle & rev, but I did notice that it sticks going from 'start' position to wot position.....
I can see where a screw on the linkage is just hitting another screw, but will get past it with a little force, or if I push slightly with a pencil....
They barely touch, but enough to impede smooth throttle.....
It seems to run the same with the cover off or on....
I've been running it attached to my boat, with a tub fed by a hose....
FR were you referring to the rubber grommet & washer that fits over the driveshaft & impeller housing?
If so, then yes, it was replaced, along with the water supply grommit......
I had it idling for at least twenty minutes & it didn't get hot.....
It does start easily.....
